For a while I have wanted to modify the  VDJ Default Pro, 4 deck skin, so that the Swap button on the lower Deck could be RIGHT  clicked to Unload the lower deck, and the normal, LEFT click Swaps the decks. (currently on the skin, both left and right clicks, swap the decks)
Logic > Right Click ? unload lower deck : Left Click ? Swap decks : nothing
I would love if this is possible to mod the skin. Any ideas or suggestions welcome.
Thanks all.
Thanks all.
Posted Wed 15 Sep 21 @ 6:59 am
          this should tell you all you need to know. Just the example really.
http://www.virtualdj.com/wiki/Skin%20Button.html
Posted Wed 15 Sep 21 @ 7:04 am
