i loaded a playlist in Automix. During play , i 've added few track from another playlist . I clicked on the bar by mistake and reseted the order alphabetically. There was no way to undo that since there was no 'reset sort order' when i right clicked on the bar nor an undo function. Is there any other way to fix such a mistake (undo) during a session ? Tnx
Posted Tue 14 Sep 21 @ 5:47 pm
Use the "order" column and reset that.
Posted Tue 14 Sep 21 @ 5:50 pm
Make the "Order" column visible on automix view.
Then you can use it to reset back..
i open the column (right click on the bar) but i cannot trace 'order'. Am I doing it wrong ?
Posted Tue 14 Sep 21 @ 6:04 pm
you need BUILD 6634 (2021-09-04) Early Access for Order field.
Posted Tue 14 Sep 21 @ 6:29 pm
It should be at the bottom
Order is always there, near the bottom since b6334
but it's not an undo function,
it can't be reordered using current column sort order
Thanks guys but my build is b5874. Sorry
Posted Tue 14 Sep 21 @ 6:32 pm
Not really a fix, but can't you just reload the playlist to get it back into original order?
Posted Wed 15 Sep 21 @ 5:51 am
