Topic: Problem with DragAndDrop
--- Translate with Google ---
Hi there,
I have had the following problem for a few days:
I manage my music files with Mediamonkey version 4.1.31.1919 and have been using VirtualDJ to play them in the last few months.
Until a few days ago I was able to play my files from MediaMonkey in VirtualDJ (V8.5-64 b6613) using drag and drop. Now after "storing" the file (an mp3 file) I get the message VirtualDJ no longer works and VirtualDJ hangs.
In the event display I get the following information from my Windos 10 version 21H1 system build 19043.1202
Name der fehlerhaften Anwendung: virtualdj.exe, Version: 8.5.6613.0, Zeitstempel: 0x6127840f
Name des fehlerhaften Moduls: ntdll.dll, Version: 10.0.19041.1202, Zeitstempel: 0x4f115fac
Ausnahmecode: 0xc0000374
Fehleroffset: 0x00000000000ff199
ID des fehlerhaften Prozesses: 0x434c
Startzeit der fehlerhaften Anwendung: 0x01d7a7d02f6d5186
Pfad der fehlerhaften Anwendung: C:\Program Files\VirtualDJ\virtualdj.exe
Pfad des fehlerhaften Moduls: C:\WINDOWS\SYSTEM32\ntdll.dll
Berichtskennung: ac088c23-cc4c-4607-b3f8-96c67241e78c
Vollständiger Name des fehlerhaften Pakets:
Anwendungs-ID, die relativ zum fehlerhaften Paket ist:
Can someone help me
Regards
Michael
Posted Sun 12 Sep 21 @ 12:39 pm
Hello
after uninstalling version 8.5.64 b6613, restarting and reinstalling version 8.5.64 b6418, the problem does not occur.
After an update from 8.5.64 b6418 to version 8.5.64 b6613, the problem is present again.
Regards
Michael
Posted Mon 13 Sep 21 @ 9:40 am
