I'm trying to write this script to filter my clean music filter folder. I want to exclude certain songs from the filter. Where am I wrong?
Posted Tue 07 Sep 21 @ 7:49 pm
nowhere, like your script seems to stay ;)
Djratedxxx919 wrote :
is missingthis script
Posted Tue 07 Sep 21 @ 8:04 pm
Sorry I for got the pic...lol
Posted Tue 07 Sep 21 @ 8:22 pm
just missing parenthesis:
filename contains clean or filename contains "radio edit" or (grouping contains hot and grouping contains classic and grouping doesn't contain slowjam)
Posted Tue 07 Sep 21 @ 9:00 pm
Ok I'm missing one thing
The grouping part need to have it where the tag must have the grouping field populated.
Posted Wed 08 Sep 21 @ 1:53 am
Grouping is not ""
Posted Wed 08 Sep 21 @ 1:59 am
locodog wrote :
Grouping is not ""
It still doesn't exclude files that have no grouping...
Grouping is how I designate files in my library that I use for doing.
Files that have no grouping should be in the filter folder.
Posted Wed 08 Sep 21 @ 2:25 am
...doesn't exclude files that have no grouping...
...have no grouping should be in the filter folder...
Contradictory statements, it's either "is" or "is not" try stuff.
Posted Wed 08 Sep 21 @ 2:52 am
Sorry I wrote it wrong...if there's no grouping in the grouping field it should not be in the filter folder.
Posted Wed 08 Sep 21 @ 2:54 am
so "is not"
type out your filter
Posted Wed 08 Sep 21 @ 2:58 am
locodog wrote :
so "is not"
What do you mean "type out your filter"?
Posted Wed 08 Sep 21 @ 5:54 am
type it out, show me what you tried that didn't work.
Posted Wed 08 Sep 21 @ 7:05 am
It's in the original post
Posted Wed 08 Sep 21 @ 3:46 pm
so you want me to read a sideways pic and type it out...
and that doesn't include where you tried inserting blank grouping part, even blindly brute forcing it there's only 6 places you'd have to try.
Posted Wed 08 Sep 21 @ 4:16 pm
Posted Wed 08 Sep 21 @ 10:08 pm
Note even I did the first part (sic) for the parenthesis I don't really understand what is the real finality either
It is necessary to explain exactly and with precision what have to be view and what not in a way to be able to create the correct script
guessing what you have in mind is not possible
really not clear what kind of grouping could be "hot classic slowjam" at the same time
make more sense
or maybe
Grouping is not "" and (filename contains clean or filename contains "radio edit" or (grouping contains hot and grouping contains classic and grouping doesn't contain slowjam) )
make more sense
grouping doesn't contain slowjam and ( filename contains clean or filename contains "radio edit" ) and ( grouping contains hot or grouping contains classic )
or maybe
Posted Wed 08 Sep 21 @ 11:03 pm
make more sense
or maybe
make more sense
or maybe
I'm trying to exclude certain tracks from the clean music folder even if they are clean radio edits.
I'm gonna try to explain. Ooook. Here we go....
I use grouping to sort my music.
So I have different groups like Slowjam, 90s HipHop, 90s R&B, Classic HipHop....and so on.
So for my clean group I want songs pulled from those groups that are label as clean. But there are certain groups I want to exclude like the slow jams, the Classic R&B, the classic Hiphop. Also I want to exclude tracks that have no grouping at all.
I hope I was clear in what I'm trying to achieve.
Posted Wed 08 Sep 21 @ 11:59 pm
Last one was closed: ( filename contains clean or filename contains "radio edit" ) and grouping is not "" and grouping doesn't contain slowjam and grouping doesn't contain classic
Posted Thu 09 Sep 21 @ 12:15 am
Thanks everyone.
Posted Thu 09 Sep 21 @ 5:04 am
