I have a DDJ-SX2. After the last update my crossfader has changed. It no longer will fade from the A side to the B side. It now cuts off the song playing completely as the fader crosses the center mark. I've tried changing many settings with no results. Has anyone else seen this and figured out the fix?
Posted Sun 11 Jul 21 @ 6:35 pm
check the crossfaderCurve setting
Posted Sun 11 Jul 21 @ 6:58 pm
Tried all the settings and nothing changed
Posted Sun 11 Jul 21 @ 7:12 pm
From your description sounds like you have 'cut' xf curve.
Posted Sun 11 Jul 21 @ 8:11 pm
