My controller is connected to the comp fine but virtual dj 8 fails every time to connect my controller… so confused I’ve updated everything I can it finally started working now it’s back to the failed to connect?? Anyone eles have this problem??
Posted Tue 22 Jun 21 @ 4:13 am
Is it the audio that doesnt work? and fails to initialize?
If so, check if Windows have taken the SB3 as its own sound card.
Set Windows back to PC sound card if thats the case.
https://winaero.com/change-default-audio-device-windows-10/
And if not, check that the sound settings used in VirtualDJ are correct
https://www.virtualdj.com/manuals/hardware/pioneer/ddjsb3/setup.html
Posted Tue 22 Jun 21 @ 10:21 am
