When loading a track I get a beeping noise through the system .
Load buttons 1 and 2 not all the time but it's loud .
Any ideas appreciated.
Sometimes it does it not always.
Many thanks 😊🙏
Many thanks 😊🙏
Posted Sat 05 Jun 21 @ 1:56 pm
Any help guys please 😊
Posted Mon 07 Jun 21 @ 2:24 pm
Computer a bit on the low end, and "freezes" a bit when loading songs perhaps?
so the playback halts..
If so, you can try set buffer higher at the asio driver (try 512, or even 1024).
Or alternatively precompute or disable stems, if your computer is not up for it. Try in VirtualDJ settings to set precomputeStems to "only use precomputed" and see if that makes a difference
Posted Mon 07 Jun 21 @ 2:55 pm
I dont use Stems.
Thanks for advice will try Asio driver thanks for advice.
Posted Mon 07 Jun 21 @ 3:02 pm
