Does anyone know if vst plugins in VDJ are limited to any size?
Saved my Groove Agent.dll today in the folder "Plugins64 - SoundEffect"
The .dll is about 100 MB
When I try to call it as a master effect it shows: "INCOMPATIBLE".
But I know for sure that my Groove Agent is 64bit....
Posted Sun 09 May 21 @ 8:15 pm
Not all VSTs are compatible...
the one you tried probably is not, as it said "incompatible"
But, sounds perhaps more like you tried use a 32-bit VST
Posted Sun 09 May 21 @ 8:44 pm
OK Thanks, wrote to Steinberg for help...
Posted Sun 09 May 21 @ 8:45 pm
Doubt they can help ... the VST (from their perspective) works as it should.
Might just be its too complicated to use with VDJ if its a full blown production suite.
(its a 500MB installer, 32 GB content libary, so perhaps not one that works an "effect" in VDJ)
and if its 32-bit, you need the 64-bit version of the VST to use with VDJ 2021 (64-bit software)
Additionally if its a very complex VSTi, it might have an associated folder (with sound files etc) that you also need to copy over.. not just the DLL file
Posted Sun 09 May 21 @ 8:50 pm
If it says INCOMPATIBLE before to be selected it's basically not recognized
- not a VST2 64bit dll
if it says INCOMPATIBLE at load time:
- missing external dll (i.e. Microsoft Visual C++ xxxx Redistributable)
- missing external non dll component (config file / presets / data folder not found)
as VDJ is not using standard install locations, may need some manual/custom install
- not enough memory
- not enough memory
Posted Sun 09 May 21 @ 8:54 pm
