Ok so the last bank is Slicer and Slicer loop.
I’ll never use those but when I try to edit them in the pad pages they don’t even show up.
Where do I find these pages so I can edit them to what I want??
This is on a Numark NV
Posted Sun 18 Apr 21 @ 6:51 pm
dont have to map anything.. just change "favorite" pads (the buttons to select type of pads above the pads on the controller) .. at least if the NV is mapped with standard pads, and I guess it is
You do this easily in the pad select drop down in the software ...
https://virtualdj.com/manuals/virtualdj/interface/decks/decksadvanced/pads.html#controller
Posted Sun 18 Apr 21 @ 6:55 pm
