Me gustaria saber si funciona VDJ 2021 con la CONTROLADORA M-AUDIO XPONENT???
ya que ni los drivers de la M-AUDIO XPONENT, he podido bajar correctamente....GRACIAS
Posted Thu 15 Apr 21 @ 8:13 am
The controller is supported in VirtualDJ mappers.
But its a very old controller (10 years old or more), the drivers might not work on modern Windows/macOS..
Can try the latest drivers
For Windows
https://m-audio.com/support/download/drivers/xponent-installer-6.0.2-driver-5.10.0.5133
For MacOS:
https://m-audio.com/support/download/drivers/xponent-osx-1.8.0
(For macOS the latest driver is from 2008, and is unlikely to work, was made for macOS 10.6.4)
Worth a try if Windows/macOS can use the audio with its own drivers.
Just connect it and see if it picks up.
For Windows
For MacOS:
Posted Thu 15 Apr 21 @ 11:01 am
SON UNOS GENIOS.....MUCHAS GRACIAS
SUPERAGRADECIDO .....es otra cosa poder usar esta CONTROLADORA con los STEMS Y LAS VENTAJAS de VDJ 2021....Saludos Cordiales desde URUGUAY
Posted Sat 17 Apr 21 @ 8:18 am
You can use stems with the controller yes ;-)
Posted Sat 17 Apr 21 @ 10:27 am
