So i have cue installed on my backup laptop. They are doing away with cue and all the support. When i go to update to the new VDJ it says it isnt compatible with my processor. Any ideas?
Posted Mon 12 Apr 21 @ 2:43 pm
what processor do you have?
Posted Mon 12 Apr 21 @ 2:49 pm
Would probably be a good idea to tell us what your processor is and where exactly you get the error message?
Posted Mon 12 Apr 21 @ 2:50 pm
For VirtualDJ 2021 you need Windows 10 (or MacOS)
If you dont have that, perhaps update your computer first
https://www.virtualdj.com/wiki/Minimum-system-requirements.html
(you can download earlier version at link above, for older computer operating system, but perhaps still best to just upgrade)
https://www.cnet.com/how-to/how-to-download-windows-10-for-free-now-that-windows-7-is-dead/
Posted Mon 12 Apr 21 @ 3:00 pm
When you have updated, you might have to copy over a few things from the CUE directory to VirutalDJ directory (they dont use same folder in /documents/)
But just post when you are ready and have updated Windows ... if that was it
Posted Mon 12 Apr 21 @ 4:19 pm
