I am using the A1 trigger gate free plugin with virtual dj.
https://www.kvraudio.com/product/a1triggergate-by-alex-hilton-a1audio
everything works fine but for one bug...in quiet parts of a track...the plugin doesn't 'hear' any input and therefore the track is muted...i just wanted to get clarity on whose end the problem may be solved...i have already contacted the developer of the plugin...there is constant noise hack setting which should have solved the problem..but it has not
Posted Tue 06 Apr 21 @ 8:09 pm
Yes this is weird
the plugin mutes (itself, mix if set to something else goes on being eared)
and it takes some time before plugin wakes up because it need a number of beats to start
constant noise hack setting solves nothing and there are 350 exposed sliders ^^
Put gate in auto mode (bottom right of bottom center black box) seems to fix the issue (does not mute anymore, goes on applying to nothing while too low aka StopMode)
MIX can help somehow too because only fx won't send anything while track part is still audible
Posted Tue 06 Apr 21 @ 9:09 pm
Enabling samples instead of hybrid mode also works but it is not synced with bpm so it sounds off
Posted Wed 07 Apr 21 @ 12:28 am
