For some reason I am having difficulty with audio going into OBS studio. Either I have gotten tech retarded or something has changed in my settings. Is anyone using a similar set up with virtual dj 2021 with OBS broadcasting can explain the audio settings into OBS?
Posted Tue 09 Feb 21 @ 4:50 pm
Similar setup to?
What do you have and how are you setting it up
Posted Tue 09 Feb 21 @ 5:56 pm
There was an update, not current one but one back that set Desktop Audio, from Default to Disabled and one needed to use the drop down in, Setting > Audio > Global Audio Devices to select the audio mapping. (IE: change from Disabled to which audio you want it to record/stream)
Check to see if Audio is configured correctly in OBS.
Cannot tell you how to configure that, since do not know how you map your audio both in VDJ and in your OS.
Posted Wed 10 Feb 21 @ 2:01 am
