Topic: Low quality, high frequency sound coming out of DDJ 400 is
Hi - I'm using a Pioneer DDJ 400 on a MacBook Pro, playing music from Rekordbox. Sound coming out of Rekordbox sounds worst than the same files (FLAC) played on iTunes, VLC, etc... It sounds like Rekordbox / DDJ 400 is trimming some low frequencies and increasing high frequencies.
As a DJ, it's really frustrating because the music I play sounds terrible...
Do you know what might be the problem? Is there a feature in DDJ 400 / Rekordbox that might be causing this issue?
Thank you!
Posted Tue 02 Feb 21 @ 3:38 am
AdionPRO InfinityCTOMember since 2006
Posted Tue 02 Feb 21 @ 4:57 am
