Hi:
MBP 2011 with OS X Yosemite I7 16GB RAM, AMD Radeon HD 6750M 1024 MB
2 SSD 5OO GB INTERNAL memories
VDJ 8.5 B6286 vers
experiencing constant program crashing and restarting when playing music videos.
Need Help ASAP
VDJ 8.5 B6286 vers
Need Help ASAP
Posted Sun 31 Jan 21 @ 10:08 pm
Do you have any videos encoded with the AV1 codec?
Posted Mon 01 Feb 21 @ 3:55 am
NO
Posted Mon 01 Feb 21 @ 6:05 pm
Rather than just saying "no", it would be useful to tell Adion what format the videos which causes crashes are in (codec etc).
Posted Mon 01 Feb 21 @ 6:25 pm
As soon as i get home will give you the requested information, the funny thing is that been using the same video format for 5 years and never experienced this situation until installed VDJ new version....
Posted Mon 01 Feb 21 @ 7:40 pm
From reading people with similar problems it seems there is a previous VDJ 8.5 version 6257 that does not experience this problem.
Is there a way to uninstall this version and go back to a version that wont have this problem???
Posted Mon 01 Feb 21 @ 8:35 pm
all music files are mp4/MPEG-4 MOVIE, never experienced problems before
Posted Mon 01 Feb 21 @ 11:04 pm
tried disabling the Math engine but everytime i choose that option it goes back to CPU
Posted Mon 01 Feb 21 @ 11:19 pm
Hi Devora, do you have solution for your question?
I have same problem with V8.5 - 64 - b6294
I'm crazy because VDJ it closes when load in some video music, but I can't identify why it, and what kind of format will close the software, before playing it.
Posted Fri 12 Feb 21 @ 2:37 am
safevideomode option (no)
Posted Tue 06 Apr 21 @ 9:32 pm
I got around all these issues by just using the 32 bit version. I have had zero problems for months now. Love it! No, I dont have stems.. so what, I have a stable platform that is 100% reliable.
Posted Sat 10 Apr 21 @ 1:53 pm
Probably would be same just disabling stems in the 64-bit version then I guess...
(aka set mathEngine in the settings to disabled, if your computer cant handle it)
Posted Sat 10 Apr 21 @ 10:41 pm
