Questions, bugs or comment related to the latest version of VirtualDJ
(NOTE: VirtualDJ continuously updated, so many older topic on this forum are most probably already fixed in the current build)
If you need extended support, contact our Support Team.
Topic: i need serious help
virtual dj is messing everything up for me right now, whats happening to the database settings. even when i restore back up databases few minutes and its gone again
Posted Thu 14 Jan 21 @ 2:00 pm
Base on your other post about not storing settings and track data, it seems like your laptop are having bigger issues
Do you have another laptop you can try, and see if you then get less problems?
Or maybe run some harddrive testing on your current one?
Posted Thu 14 Jan 21 @ 2:20 pm
i don't have another laptop.....ill try running hard drive test, thanks for reaching out. I'm going crazy rn
Posted Thu 14 Jan 21 @ 2:27 pm
Maybe a fresh windows install will help
But of course not if your harddrive is failing
Posted Thu 14 Jan 21 @ 2:32 pm
From his other thread "I'm using a MacBook pro late 2012"
Posted Thu 14 Jan 21 @ 2:36 pm
AdionPRO InfinityCTOMember since 2006
Also, please continue in one thread. It gets really difficult to gather all the information in different topics.
Posted Thu 14 Jan 21 @ 3:30 pm
