Topic: How to Sync to a Variable Beat Grid
Is there a way to sync to variable BPM track.
Assume you have used the BPM Editor to adjust the grid. And now there are sections of the track that are 128.47 and other places its 128.56 and another place section where BPM is 127.9. Now we play this track on deck 1.
Then on deck 2, one syncs a 128 BPM track to deck 1, initially the they will be perfectly synced at 128.47 then when the BPM of deck 1 changes to 128.56 they become out of sync.
I have tried to use AUTO PITCH LOCK, and sync them so the paddle-lock icon is ON(lite).. but deck 2 does NOT stay in sync when deck 1's BPM changes.
Is there a way to enable that?
Poor work around is to create labeled, (marker only) cue points, and press the sync button every beat till past each, marked BPM, change. Would love the software to press the sync button for me.
Posted Sun 10 Jan 21 @ 12:20 pm
AdionPRO InfinityCTOMember since 2006
beatlock
Posted Sun 10 Jan 21 @ 12:24 pm
Amazing and thank you ..
Always learning all of capabilities of VDJ
Works perfectly :)
Posted Sun 10 Jan 21 @ 12:30 pm
