Hello everyone, I wish you happy holidays.
I would like to know if in the multi touch skin it is possible to have this?
How to block the pads and pages under the decks and how to add a color to them?
Because when I click on the pages of the pad pages that I have created I have other unwanted elements. Or how do I add the desired pads?
- modify the skin and only have 1 deck or 2 maximum?
- How to block access to folders in the show browser to block access to folders and hard drives?
Thanks for your help.
Posted Sun 27 Dec 20 @ 7:17 am
need some clarification
what do you mean by "block the pads" and "block the access to folder" ? hide them ? fixed values ? something else ?
and what are these "other unwanted elements" ? maybe some screenshot ?
pad position (and some other small panels items) have to be adjust in a way not to resize wrongly
(fixed in proposal, everything we already did)
color for pads was already answered in previous thread, with xml code for push effect
1 and 2 decks only is already possible (long press deck selector) but currently need some improvement when 3 or 4 is showing
(fixed in proposal)
block the access to folders ? if it's to remove the folder list or hide it yes
just need some skin modification to allow to disable folderlist
show_splitpanel justfolders 0% hides it
lock_panel justfolders is not documented
maybe hide separator too all near line 6028 / 6180 (depending on original or modified version)
but controller and keyboard functions will go on being accessible to navigate blindly :'(
(not multitouch skin specific) VDJ can't disable browsing
(fixed in proposal)
Posted Sun 27 Dec 20 @ 10:35 am
