Hi there anyone know what requirements are for stems on MacBook ? I know Catalina or Mojave but it's said additional for stems isolation amd video card I'm confused now , can somebody help what spec of MacBook I need for version 2021 with stems .Thanks!
Posted Wed 02 Dec 20 @ 7:52 pm
On mac, a Radeon gpu is recommended for fastest stems processing.
If you are in the market for a new mac and 13" is fine you should consider the new MacBook Air or MacBook Pro with M1 processor as well though, as they have been found to also be very fast for stems processing.
Posted Thu 03 Dec 20 @ 5:40 am
Thanks man!
Posted Thu 03 Dec 20 @ 11:34 pm
Hi
I know macbook run the software well but lately my macbook struggles with stems. I have a mid 2014 with Iris intel video card 1536mb. If a i buy a newer model mac should i consider the new mac with 16gm. The only thing holding me back is the video card and the lack of ports on the 13 macbook.
Or should consider PC ?
Posted Wed 09 Dec 20 @ 8:02 am
I have tried on latest mac13 m1 cpu I had crash first time ever and it was on MacBook ,never on windows I think Vdj is rock stable on windows
Posted Fri 11 Dec 20 @ 11:05 am
Bowlingdj I would suggest you that you go for thinkpad P series 53 or if you got money buy better one ,I think the Vdj is rock solid on windows. Thinkpad is the way to go or normal gaming machine who is got good graphics card.
Posted Wed 16 Dec 20 @ 2:15 pm
Thanks i been a mac user too long all my external drives are mac os. i been on fence with windows though you get the most bang for the buck.
Posted Thu 25 Feb 21 @ 5:53 pm
I use nothing but Macs and everything is rock solid! And I push my machines as far as they’ll go.
Running multiple live camera feeds, lighting software, projection mapping with Resolume, video samples, video fxs and more.
I do weddings, play clubs, private parties and I’ve never had a crash live.
Honestly for me I’ll never go back to windows.
I recently bought a new M1 MacBook Pro and VDJ is rock solid so far. Again I’m running VDJ with cameras and SoundSwitch running in the background.
Stick with the Mac 🤙🏾
Posted Fri 26 Feb 21 @ 11:22 pm
Heres a test record I did.
Im running 3 instances of Shaders with 2 instances of slideshow. Recording at 1920x1080
The M1 didn't even flinch!!
Posted Sun 28 Feb 21 @ 8:30 pm
YouTube gqW98POQpiw
Hi,
as I m looking for a new MacBook to buy, would you recommend Pro over Air ? And also are 8GB enough or should i go for 16 ? Thx
F.
YouTube gqW98POQpiw
Hi,
F.
Posted Fri 26 Mar 21 @ 5:46 am
I bought a new MacBook MacBook Pro M1 (8go / 256go ssd / 13’’).
VDJ 2021 runs perfectly.
With 2 calculation of stems in the same time, the cpu is loaded at 20-25%
Posted Fri 26 Mar 21 @ 9:27 am
