When I am using timecode (serato) and practicing juggling with tap pauses (short bursts of releases and stops using my hand) and master tempo enabled, I can here there are cases where the pitch of the song actually changes after a few releases, with the pitch actually staying at the new invalid level until another stop of the record. I do not have Virtual DJ timecode but I did try it with phase using the VirtualDJ signal and I see the same problem.
Posted Thu 26 Nov 20 @ 2:35 pm
Could you try by changing the option "pitch quality" in the settings?
Posted Fri 27 Nov 20 @ 10:48 pm
I tried with the pitch quality at 1, 2 and 3 with phase (virtualdj signal) and serato timecode - the issue still persisted.
Posted Sat 28 Nov 20 @ 1:57 am
Hi Dj Cel, do you have any further suggestions to try or if not, will this be reported as a Bug to be fixed?
Posted Sun 06 Dec 20 @ 10:38 pm
This is the only issue that is preventing me from switching full-time to VDJ. I haven't found a setting that has eliminated this issue and I think this may be an issue for people who beat juggle a lot.
Posted Wed 24 Mar 21 @ 6:58 pm
