About VirtualDJ and DJing in general
If you need extended support, contact our Support Team.
Forum Guidelines  (*) The moderators hold the rights to remove, move or modify posts.
Topic: [Solved]Cue Points not saving. - Page: 1
speng1PRO InfinityMember since 2010
I'm sorry to ask this question. my Cue points are not saving. I just set 10 cue points, turned of VDJ and reloaded and they disappeared.
I have my write permissions turned on ( box checked yes ) Full control. Read is checked yes. Every box is checked with a tick.
Any advice please.
Posted Sun 22 Nov 20 @ 1:08 pm
External drive or drive other than the local C drive?
If so you might have to add permission to the folder /virtualdj/ on that drive ..
VirtualDJ saves the database to each drive for music on that drive.
Posted Sun 22 Nov 20 @ 1:38 pm
Its my internal drive.
Posted Sun 22 Nov 20 @ 1:40 pm
how do I add permissions ? I know where to go but what do I input ?
Posted Sun 22 Nov 20 @ 1:41 pm
Should read be unchecked ?
Posted Sun 22 Nov 20 @ 1:50 pm
Do you want to be able to read files? If yes, then check it.
Posted Sun 22 Nov 20 @ 1:52 pm
ok .everything was checked yes
Posted Sun 22 Nov 20 @ 1:54 pm
Posted Sun 22 Nov 20 @ 1:57 pm
hello i
n the windows rhythm display is it showing Cue1 ?
because you have to know the action Cue 1 remains recorded
and the cue action is is temporary.
Posted Sun 22 Nov 20 @ 1:58 pm
Posted Sun 22 Nov 20 @ 2:03 pm
LIMOL wrote :
hello i
Yes it shows cue 1. I set 6 cue points on several tracks and reloaded vdj and they all disappeared.
Posted Sun 22 Nov 20 @ 2:04 pm
Check the notches anyway
Posted Sun 22 Nov 20 @ 2:24 pm
ok
Posted Sun 22 Nov 20 @ 2:52 pm
Perhaps getCuesfromTag is set to always ?
Posted Sun 22 Nov 20 @ 3:35 pm
No. Still no luck.
Posted Sun 22 Nov 20 @ 3:46 pm
Ok. I just did a check. I moved my existing VDJ folder out of documents. That created a new one when opened. I loaded 5 files on to the decks and saved cues on each. I then shut down VDJ and restarted and cue points returned ? So that must mean that something is wrong with my original VDJ folder some where ?
Posted Sun 22 Nov 20 @ 3:48 pm
weird your vdj version?
Posted Sun 22 Nov 20 @ 3:51 pm
2020
Posted Sun 22 Nov 20 @ 3:52 pm
could be because ive moved it from several laptops in the past and accidentally didnt keep the same name. maybe somewhere its corrupted but all my previois cue points any bpms are all there. It sonly happening when i add new cue points.
Posted Sun 22 Nov 20 @ 3:53 pm
locodogPRO InfinityModeratorMember since 2013
Any chance you set the readOnly setting to true?
Posted Sun 22 Nov 20 @ 3:56 pm
Page : [>] [>>]
69%
