Hi !
I'm using the latest version of Virtual DJ with the new Numark Platinum FX Pro.
When i'm turning any of the High/Mid/Low knob on low or fully off , a weird distorted sound comes in ,like theres a low quality song from youtube.
Anyone has any idea how to fix this ?
Cheers :)
Cheers :)
Posted Sun 18 Oct 20 @ 3:08 pm
VDJ 2021 has a new feature:
https://www.virtualdj.com/help/stems.html
If you don't need it (or don't like it), just disable it.
Posted Sun 18 Oct 20 @ 3:24 pm
