Hi everybody,
i just bought an Hercules DJControl Starlight, which (imho) is a nice little toy.
Atm i changed the default mapping to my needs.
So far, so good, but i cannot get the Filtermode (Switch between the Knobs are for Bass or Filter) always to be on when the controller gets connected.
I tried "ONINIT" with "FILTERMODE on", but this doesnt work.
Other tries with active, 1, and so on doesnt help, too.
So the question is: Can it be somehow be done to have the filtermode active when the controller gets connected or VDJ gets started?
Thanks forward.
Best Regards,
Andy
Thanks forward.
Best Regards,
Andy
Posted Thu 15 Oct 20 @ 9:41 am
I dont have the controller, but this might be a hardware switch.
If so, the software might not be able to change that.
Look in settings, in VirtualDJ, and search Starlight.
Is there a setting there for this? if so you can map an action to set this oninit
Posted Thu 15 Oct 20 @ 1:57 pm
The switch is a hardware functionality, so you cant map it. What you could if you only need Filter and no EQ Low, is to map the key EQ_LOW as filter
Posted Thu 15 Oct 20 @ 6:28 pm
@Rune:
Within the options i can only find settings for the LEDs.
@djdad:
Good to know and sad it is a hardware-switch.
I use booth, bass and filter, but with this small controller i use the most time the filter.
@djdad:
Posted Sun 18 Oct 20 @ 1:16 pm
