Hello everyone, I'm looking to make a script so that when I turn on my microphone it puts my master volume to 0 and when I press my key again it puts my master volume to 1 and mutes my microphone.
i have tried that but dosen't work :/ can you help me please. :)
mic on & master_volume 0 : mic off & master_volume 1
Posted Sat 10 Oct 20 @ 4:31 pm
Hnag on - what's the point of having the mic on when master volume is at zero? Nobody will hear it.
Posted Sat 10 Oct 20 @ 5:01 pm
Because my principal sound i record my heaphone sound and on it i don't need to have master is juste for my speakers i want to reduce the sound of my speakers when my mic is on :)
Posted Sat 10 Oct 20 @ 5:16 pm
So how do you cue?
Posted Sat 10 Oct 20 @ 5:20 pm
mic on & deck all level 0 : mic off & deck all level 1
try that, it could be tweaked further,
master_level is EVERYTHING so what you see is expected.
So how do you cue?
So how do you cue?
in another soundcard with another speakers it's more for radio utilisation
Posted Sat 10 Oct 20 @ 5:44 pm
it dosen't work when my mic is open i can't turn off
my mistake, wasn't paying full attention, try this
mic off ? mic on & deck all level 0 : mic off & deck all level 1
Posted Sat 10 Oct 20 @ 5:55 pm
thank you too much it's works
Posted Sat 10 Oct 20 @ 6:11 pm
no worries, you own a small part of the SW now, you wanted it to work "this way" and now it works the way you wanted.
Posted Sat 10 Oct 20 @ 6:39 pm
my mistake i type "&" where "?" was expected ^^
Posted Sun 11 Oct 20 @ 12:07 am
Please le me know if you solve this as exactly what I was hopping could be done simply by mapping. In needs to work both ways eg , turn mic up cuts master . Turn up master cuts mic. Good luck
Posted Sun 11 Oct 20 @ 10:08 pm
It was already posted as an answer:
Posted Mon 12 Oct 20 @ 8:03 am
You could also use mic_talkover for this
mic_talkover 0%
Posted Mon 12 Oct 20 @ 8:20 am
That would mute the music, but the mic would still be audible. People here are asking for the master output to be muted, which would include the mic.
Posted Mon 12 Oct 20 @ 8:30 am
What would be the point of turning on the mic if you don't want to hear it?
Posted Mon 12 Oct 20 @ 8:39 am
That's what I said (see post #2), but the customer wants it to work that way.
Posted Mon 12 Oct 20 @ 8:50 am
He did reply "thank you so much it worked" for the script using level though, which is the same as mic_talkover and indeed different from user master volume
Posted Tue 13 Oct 20 @ 4:28 am
