i was always passionate about virtual dj. however i purchased a Dixon midi 7 controller/mixer and it has no serial number. Please help.
Posted Thu 20 Aug 20 @ 7:59 pm
You can buy a plus license for that controller inside VirtualDJ, if you mean for home use, probably around $49-99 range.
Else pro license, that works with all supported controllers for $19/m (or $299)
Look in license settings when you open the software, since that will auto detect this controller (its a bit of a generic controller, so might say WellJoint, FFactories or similar as detected instead of Dixon)
Posted Thu 20 Aug 20 @ 8:14 pm
I need to open a license
Posted Sun 29 May 22 @ 4:32 pm
go here https://www.virtualdj.com/buy/index.html?product=promonthly
Posted Sun 29 May 22 @ 6:41 pm
Hello there , I got a problem with my DXNPRO MIDI7 Controller . When i connect it to Virtual Dj all knobs and buttons work on both deck 1 and 2 but , when deck 1 playing a song then deck 2 Cue , Pause and Play don't want to work . Please help
Posted Fri 09 Aug 24 @ 5:01 pm
I need to connect to PC
Posted Thu 29 May 25 @ 6:37 pm
