Hi
Need some help. Want to use a POI to turn Vocals off (to remove offensive words) the back on again.
Have created a POI, marker only, point and set action to stem "Vocal 0"
see image from POI editor, below
https://www.virtualdj.com/img/318228/827/POI%20STEMS.png
What would be the correct syntax/script ?
I would then create another POI to turn vocals back on.
Thanks
Thanks
Posted Sun 02 Aug 20 @ 11:29 pm
use
You can use this to mute the vocal and it will bring it back again on another POI
mute_stem 'vocal'
Posted Sun 02 Aug 20 @ 11:46 pm
I'd rather use the track editor to reverse the bad words and create a clean version of the track.
So you can keep both separated in case you ever want to play the dirty version.
https://virtualdj.com/manuals/virtualdj/editors/trackcleaner.html
Posted Mon 03 Aug 20 @ 6:45 am
I asked in the wishes area for this recently. I do think it would be very useful to utilise the stems function to mute vocals rather than reverse whole sections.
At least this way the music stays intact (doesn't play backwards).
Posted Mon 03 Aug 20 @ 7:15 am
