About VirtualDJ and DJing in general
If you need extended support, contact our Support Team.
Forum Guidelines  (*) The moderators hold the rights to remove, move or modify posts.
Topic: Audio broadcasting via link
Posted 7 days ago @ 11:58 am
Might just be that the sound card is already in use, if you are trying to mix and listen on same computer ;-)
If you try tune in on phone or other computer...
Posted 7 days ago @ 1:22 pm
I am mixing in PC and listen to in Android web browser - doesn't work (I do not hear sound)
Posted 7 days ago @ 4:26 pm
user22444013 wrote :
Android web browser
Via your mobile service provider (phone signal) or via your own wifi?
Posted 7 days ago @ 4:37 pm
In both connections. Also, I gave the link to my friend. The result is the same.
Posted 6 days ago @ 9:34 am
