Hi everyone, needing a wee bit support setting a system up for Twitch streaming. My setup is VDJ8 and using an American Audio VMS2 External Mixer.
The setup in general works absolutely fine and the Twitch Stream is live, and stable. However I cannot see how to get my Microphone audio out on to the live stream.
Using the ASIO drivers where Deck 1 is Out 1 & 2, Deck 2 is Out 3 & 4.
What do I configure for the Mix output? I can't get any combination (well so far) to work. Drop the channel fader on the VMS2, and the Mic is completely silent however it registers on the VMS2 Master Output Meter. So it comes out of the in-house speakers no problem.....just not on to the Twitch stream.
Anyone set up something similar that works, and I can copy?
Thanks
Kev
Thanks
Kev
Posted Fri 24 Jul 20 @ 3:46 pm
It's in the setup guide...
http://www.virtualdj.com/manuals/hardware/americanaudio/vms2/record.html
Posted Fri 24 Jul 20 @ 4:14 pm
Ha, of course it's that simple.... read the manual! Thanks for the pointer.
If I'm taking a different approach, how would I set it up with a USB microphone? Spotted a mic Link cable where the USB Cable is it's own Soundcard. So would that work and what would the config be?
Guessing I'm setting MIC for the new Soundcard as an Input but would that transmit through to the Twitch stream?
Thanks in advance
Kev
Thanks in advance
Kev
Posted Fri 24 Jul 20 @ 8:55 pm
