Topic: Disable Right Click hold and press on touch screen
Just wondering if anyone knows about how to remove right click ( Hold and press ) as for clients that will be using virtual will have access to the context menu when right clicking songs and can delete remove or change the name of some files, we have tried gpedit, regedit and software online but cannot find anything thanks
Posted Mon 13 Jul 20 @ 3:08 am
NicotuxHome userMember since 2014
in control panel, open "pen & touch" you can map actions for "Hold and press" and "Double click"
Posted Mon 13 Jul 20 @ 3:19 am
Thanks for the reply nicotux but thats not what im looking for unfortunately i have had a look at pen and touch even turned it off and the press and hold still shows on virtual, just wondering if there was any way to disable the function of press and hold
Posted Mon 13 Jul 20 @ 3:31 am
Sorry, using touch screens with VDJ and never get right click to work with it
and "touch and hold" does not display once disabled from control panel
in fact, even not showing (and correctly disabled in windows) it seems VDJ is using its own handling methodes
possible related settings are (skins) touchScreenMode and onScreenKeyboard in combination with action "show_keyboard"
that a strange combination disabling drag/drop from coverflow in some cases
Posted Mon 13 Jul 20 @ 4:02 am
Sorry Im not understanding, I am unsure how to create codes at all, am i able to send you the xml Skin file and you could help me out thank you
Posted Mon 13 Jul 20 @ 5:22 am
Ah, I didn't understand that makes sense now,
editing the skin xml in a way to disable browser functionalities is not possible AFAIK
yes keeping only simple left click and scroll in a "protected touch mode" would be usefull for digital signage with client navigation / file selection
but VDJ is a DJ software before all. It is not design to client access :\
Posted Mon 13 Jul 20 @ 6:13 am
