Topic: No vocal removing in VDJ 2021
I Have a Laptop 8 gb ram and 64 bits Windows 10 that the vocal removing and anything else works fine. but my Pc 16gb ram and 64 bits Windows 10 vocal removing does not work. its is something missing? Help please
Posted Thu 02 Jul 20 @ 11:22 pm
bonsoir,
vérifier dans l'option si le Eqmode est bien sur EZRemix
vérifier aussi dans l'option si le MathEngine est bien sur CPU
Posted Fri 03 Jul 20 @ 12:13 am
Ihave check the EZ Remix window but still does not work, also my CPU is very low in consumption for the VDJ Program
Posted Fri 03 Jul 20 @ 6:23 am
Go to settings and search "MathEngine".
Choose GPU from the 'menu'.
If GPU is not possible, you will get an error from VDJ software.
Posted Fri 03 Jul 20 @ 10:29 am
nvm
Posted Fri 03 Jul 20 @ 12:44 pm
