Do you have to be a pro infinity subscriber??
Posted Fri 26 Jun 20 @ 10:07 am
Hi. I am setting up Virtual DJ 2021 on new computer for home kareoke. I am using the audio port or jack (for the headphones). Master is set as Computer Sound Card-Speakers, channels 1 and 2. I have no other sound card. However, the music does not sound right, missing part of it, sound subdued.
I used the same connection with VDj 7 and 8 with no issues. Audio sound comes out right when listening to Utube.
Posted Fri 03 Jul 20 @ 1:53 pm
hi, i have sound problems with the new version of virtual dj 2021, I would like to go back to 2020 how can i download it for mac, thanks in advance
Posted Sat 04 Jul 20 @ 4:11 am
1) Go to the VDJ wiki page
2) Select "Download Previous Builds"
You should report the issue properly and give details, rather than just saying you have problems.
Posted Sat 04 Jul 20 @ 7:50 am
Wow, this virtualDJ 2021 is so cool, i love it, everything is working normal as usual both the stems and other features. I think this is a best version of virtualDJ 8 ever.
Posted Tue 07 Jul 20 @ 8:37 pm
Im a pro user, i uninstalled 2020 and have tried 20+ times to install 2021 i get the error message " The specified account already exists" i went as far as purchasing a second licence with the same results, i have a 64bit laptop. if this cant be resolved before my next gig 2 days from now i will cancel both licenses, i have a business to run.. i havent had any issues untill now. awesome software but damn!
Posted Mon 13 Jul 20 @ 12:09 am
Another user had the issue about specified account. Its a Windows issue. They fixed it here: https://support.microsoft.com/en-us/help/17588/windows-fix-problems-that-block-programs-being-installed-or-removed
Posted Mon 13 Jul 20 @ 12:16 am
I have a Windows 10 64bit Laptop and a Windows 8.1 64bit Laptop. Can VDJ 2021 run on my Windows 8.1 PC?
Also, my Windows 10 64bit laptop still shows the previous build. Was VDJ 2021 [with the STEMS feature] an automatic upgrade, or do you have to download it and install it over your previous version? I really don't want to do this cause last year I got an upgrade from VDJ 8 to VDJ 2020 and ALL OF MY FILTERS, AND COLOR CODED FILES defaulted back to the original setup.
I did download VDJ 2021, but I am afraid to install it due to the concerns above.
Any ideas would be appreciated.
Posted Mon 20 Jul 20 @ 2:39 am
need help download it
Posted Wed 19 Aug 20 @ 10:09 pm
Here : https://www.virtualdj.com/download/
Posted Thu 20 Aug 20 @ 12:34 pm
I have windows 8pro 64bit i5 laptop but it won't run why
Posted Fri 21 Aug 20 @ 3:15 pm
If by "it" you're referring to VDJ 2021, it requires Windows 10.
Posted Fri 21 Aug 20 @ 3:26 pm
why does it say "it is supported on windows 7,8and 10 yet it is only supported on windows 10
Posted Sun 23 Aug 20 @ 3:27 pm
The VirtualDJ software will run on older outdated operating systems, but VDJ 2021 (the latest 64 bit version with stems technology) requires Windows 10.
Posted Sun 23 Aug 20 @ 3:38 pm
-> The VirtualDJ software will run on older outdated operating systems, but VDJ 2021 (the latest 64 bit version with stems technology) requires Windows 10. <-
I just installed VDJ 2021 on my Windows 8.1 (64bit) System and it's working. I don't understand why anywhere is said, that Windows 10 is required? It's just not true.
I needed downloaded it directly, because my Browser only lead to the older VDJ Version, so this is the direct Link to the 64bit Version:
https://www.virtualdj.com/download/pc64
The Stem feature initially didn't work , but after downloading the 2 core DLL's:
http://download.virtualdj.com/cud101.dll & http://download.virtualdj.com/cuf101.dll
and copy them into the C:\Users\...\Documents\VirtualDJ\Plugins64
All running on an old System with AMD Athlon II X4 640 CPU + NVIDIA 1060OC GPU, that is also detected and used by the Math System for the Stems.
I just notice that the stem calculation for a 7~ Minutes Track, still take like aprox. 3-4 Seconds, but it's fully working so far, without Windows 10 !
maybe this helps. Cheers
Posted Fri 02 Oct 20 @ 1:02 am
