For reporting any bug, questions or comment related to the latest version of VirtualDJ
(NOTE: VirtualDJ continuously updated, so many older topic on this forum are most probably already fixed in the current build)
If you need extended support, contact our Support Team.
Forum Guidelines  (*) The moderators hold the rights to remove, move or modify posts.
Topic: [SOLVED] glitch noise every 10 seconds v2021 - Page: 1
hi ,
the new version is amazing
however im having an issue ,there is a glitch every 10 seconds with the stems function activated
it sounds like a brief stab of white noise
i downloaded the update for VDJ today b5922, but it has not fixed the issue
Posted Sat 20 Jun 20 @ 12:37 am
 Best Answer we're happy to report that this has been fixed in the latest EarlyAccess build (5929)
Posted Sun 21 Jun 20 @ 2:09 pm[ selected best answer by Stephane Clavel on Sun 21 Jun 20 @ 2:09 pm ]
Same problem here only after activating one of the new stem features
Posted Sat 20 Jun 20 @ 3:47 am
we're looking into this, as it has already been reported in another thread.
Rest assured we will fix as soon as possible.
To get more information:
- which samplerate (44.1Khz, 48Khz, 96Khz ?) are the files you are playing when you get this ?
- do you get this only when using GPU engine? if also on CPU engine, is it the same problem (glitch on waveform, and in sound output when using stem) ?
- do you get this only on the right channel? or it's on both channels?
- if you play only one of the 5 stem, do you hear the glitch no matter which stem, or only one/some of them?
Posted Sat 20 Jun 20 @ 4:27 am
my system is playing at 48k
both CPU and GPU
yes, it is only on the right channel
it happens on all of the stems
only happens when the song is playing
it happens with WAVs, MP3s and Videos
Posted Sat 20 Jun 20 @ 10:16 am
I am following this thread. Same problem. I see a big consistency in graphics cards with this same issue.
Nvidia GTX 1060. That's what I have too.
Posted Sat 20 Jun 20 @ 11:32 am
- 44.1Khz mp3s
- only when using GPU engine - when using the cpu engine it sounds like a blip of bass line instead of noise - i haven't noticed it on the waveform at all
- only on the right channel
- hear the glitch no matter which stem i take out
system Windows 10 64bit
i5 - 8400 cpu
16 GB ram
GTX - 1060 graphics
Posted Sat 20 Jun 20 @ 11:59 am
Instead of taking out a stem, can you try on the opposite to keep just one stem (right-click on stem pad).
See on which stem the glitch is.
Posted Sat 20 Jun 20 @ 2:21 pm
Matty1000 wrote :
both CPU and GPU
And you have the exact same distorsion on both MathEngine=CPU and MathEngine=GPU ?
(other seemed to report it was different)
Posted Sat 20 Jun 20 @ 2:22 pm
can someone who has this problem makes a small .wav recording of the glitch using virtualdj's recording function, ideally playing only the stem that glitches, around 30-40s long, and put it on a dropbox or other file sharing link?
Posted Sat 20 Jun 20 @ 2:51 pm
It's on them all guess i wasn't clear
I had a mp3 of it in my other thread if you need that
Posted Sat 20 Jun 20 @ 3:06 pm
Posted Sat 20 Jun 20 @ 3:54 pm
Posted Sat 20 Jun 20 @ 5:50 pm
Seeing the same HP laptop does fine.. Built computer with a 1060 6gb card does it.. Scratch noise if set to GPU large swell of lyrics if they are selected if using CPU all about at a full measure Same spots and shows on the waveform.. Right channel only. does it on all songs I have tried.
Posted Sat 20 Jun 20 @ 6:53 pm
stevoqxPRO InfinityMember since 2011
Same problem here! Every circle is a noise.
Posted Sat 20 Jun 20 @ 7:50 pm
Posted Sat 20 Jun 20 @ 7:51 pm
The recording isn't working anymore!
These are my specs.
Posted Sat 20 Jun 20 @ 8:00 pm
Recording works allright. I forget that you need a controller being connected. I will post it on YouTube
Posted Sat 20 Jun 20 @ 8:25 pm
Posted Sat 20 Jun 20 @ 8:46 pm
djcelPRO InfinityModeratorMember since 2004
Could you make the same screenshot of the skin with the same song on both check (synchronysed, ie same timing, same MEL/VOX)?
Posted Sat 20 Jun 20 @ 9:50 pm
Posted Sat 20 Jun 20 @ 9:59 pm
Page : [>] [>>]
54%
