VDJ Says it Running but will not open, task manager says it not running? was working fine up until 24 hours ago, I have deleted it and reinstalled it, didn't seem to fix the issue any one got any advise
Posted Sat 09 May 20 @ 1:54 am
maybe spurious thread not exiting - or crash report uploading -
https://www.virtualdj.com/forums/231206/VirtualDJ_Technical_Support/VirtualDJ_is_Already_Running_____.html?search=resource%20monitor&page=1
Posted Sat 09 May 20 @ 2:10 am
Where did you look? Apps or Background processes?
The only time VDJ will warn you that it's already running.......is when it's already running.
It's quite common for multiple VDJs to be listed under Background Processes. In fact I've just found a stray one on my system!
Posted Sat 09 May 20 @ 7:17 am
