Topic: Running VDJ on AWS
I'm trying to run the VDJ on an AWS cloud instance and have it downloaded, running, add songs and press play and it just stutters and doesn't play.
Everything seems fine. Song loads up. Press Play and the play button lights up and nothing. The time counter doesn't run down nor run up.
Just nothing.
Thoughts?
Posted Sat 25 Apr 20 @ 5:29 pm
Apart from it being on Amazon Cloud (assuming you run some virtualized Windows environment with challenges that might impose), generally speaking if the time counter doesnt start with play button, usually thats because the sound settings are incorrect.
Posted Sat 25 Apr 20 @ 5:46 pm
