Hi i need help
I created a custom skin for vdj 8 with resolution of 2560 by 1024
I have 3 screens with resolution of 1280 by 1024 extended desktop.
Now the skin is scrambled because the vdj8 program opens in in 1280 by 1024 only and wont get my skin over the 2 screens like the skin resolution are.
What can i do or can i convert the skin to vdj 7
Posted Fri 03 Apr 20 @ 5:05 pm
Are your skins set up in mirrored or separate display mode?
Posted Fri 03 Apr 20 @ 7:49 pm
Hi there.
My skinns are extended mode.
My desktop extends over all 3 but vdj opens only on one wpnt use thecredulution of 2.
Posted Sat 04 Apr 20 @ 1:30 am
I use window 7
My extended deisplybsetup are from one graphics card.
Posted Sat 04 Apr 20 @ 1:35 am
If maximized, skin will show on primary monitor. You need to maximize off, then manually resize to cover all monitors.
Posted Sat 04 Apr 20 @ 5:23 am
Hi dj dad i use vdj 8 2020 and no it wont drag over notveven unmaximized
Doesnt have the ability of a border to rrag it biger
Can i add a border tothe skin to drag it
If so can i use youre skin creator program to do it and how.
Regards
Regards
Posted Sat 04 Apr 20 @ 6:10 am
So if someone can help me asto get the skin spanned over 2 screens it would be great help.
Because the skin resolution is for both screens but stil the program will only open over one screen squashing my skin in.
Posted Sun 05 Apr 20 @ 6:32 am
https://www.virtualdj.com/wiki/Skin%20GrabZone.html
Alternatively you could design your skin with one main window (normal screen size) and two popup windows. See https://www.virtualdj.com/wiki/Split%20Window.html
Posted Sun 05 Apr 20 @ 7:41 am
Thanks can you help me with code for the grabzone please
Posted Sun 05 Apr 20 @ 9:21 am
Posted Sun 05 Apr 20 @ 9:22 am
Obe more thing if i open the skin in vdj 7 then its ok but vu not working and most elements what can it be i use djdad skin creator
Posted Sun 05 Apr 20 @ 9:25 am
The best solution is to delete VDJ 7.
VDJ 8 is the current version, and tools like Skin Creator are designed for use with VDJ 8, not the old unsupported software.
I would suggest you use Skin Builder instead. It's more up to date (using vector graphics) and easier to use.
Posted Sun 05 Apr 20 @ 9:37 am
Problem is vdj 8 uses creen res not the skin res but vdj 7 uses skin res not screen res.
So if i use vdj 8 i need it to use the skin res not the screen res
Posted Sun 05 Apr 20 @ 9:47 am
Because if it wil use skin res then it wil be over 2 screen
Posted Sun 05 Apr 20 @ 9:48 am
Id love to use vdj 8 but still it wont use skin resolution it only uses screen resolution of one screen only not of both my screens
Posted Sun 05 Apr 20 @ 9:53 am
Please - you do not need to make separate posts for every sentence.
It's perfectly possible to make a VDJ 8 skin (in any resolution) that can be used on multiple screens.
Posted Sun 05 Apr 20 @ 10:08 am
Ok sory for multinpost. Can younasist with skin then cause if i do it it wont gonovercthe 2 skins but fit the 2560 in on 1280 screen not over the 2 so what am o doin wrong. I have a pngbimage file of my skin with space for the buttons vu sliders and so on soni used dj dads creator to add the buttons vu and all elsecin to the spaces on the skin.
Posted Sun 05 Apr 20 @ 10:14 am
<skin name="My Skin" comment="My First Skin with Skin Creator" author="LEONARD" preview="lEDSONIC 4800 DJ 1.png" version="8" nbdecks="2" width="2560" height="1024">
<button action="nothing" >
<pos x="1202" y="82" />
<size width="22" height="13" />
<up x="5" y="1029" />
<selected x="37" y="1029" />
</button>
<pos x="1202" y="121" />
<up x="79" y="1029" />
</button>
<pos x="1202" y="160" />
<up x="121" y="1029" />
<over x="153" y="1029" />
</button>
<pos x="1407" y="52" />
<up x="195" y="1029" />
<selected x="227" y="1029" />
</button>
<slider deck="master" orientation="vertical" action="crossfader" >
<pos x="1137" y="54" />
<size width="35" height="185" />
<off x="269" y="1029" />
<on x="314" y="1029" />
<fader>
<size width="32" height="19" />
<pos x="361" y="1113" />
</fader>
</slider>
<square radius="0" border="1" border_color="#ff000000" color="#ff000000" >
<pos x="1303" y="99" />
<size width="223" height="18" />
</square>
<visual deck="master" type="linear" source="record_vu" orientation="horizontal" >
<pos x="1307" y="103" />
<size width="215" height="11" />
<off x="418" y="1033" />
<on x="651" y="1033" />
</visual>
<pos x="1302" y="146" />
</square>
<visual deck="master" type="linear" source="get_vu_meter" orientation="horizontal" >
<pos x="1306" y="150" />
<size width="214" height="11" />
<off x="894" y="1033" />
<on x="1127" y="1033" />
</visual>
<textzone deck="left" >
<pos x="1301" y="196" />
<size width="94" height="20" />
<text size="14" font="Arial" align="center" color="#ffffd700" action="get_time_min" />
</textzone>
<textzone deck="right" >
<pos x="1433" y="196" />
</textzone>
<pos x="1573" y="87" />
<size width="401" height="18" />
<text size="18" font="Arial" weight="bold" align="center" color="#ffffd700" action="get_artist" />
</textzone>
<pos x="1574" y="160" />
</textzone>
<pos x="1574" y="122" />
<size width="400" height="22" />
<text size="18" font="Arial" weight="bold" align="center" color="#ffffd700" action="get_title" />
</textzone>
<pos x="1574" y="198" />
</textzone>
<dropzone deck="left">
<pos x="103" y="22" />
<size width="466" height="299" />
</dropzone>
<dropzone deck="right">
<pos x="610" y="24" />
</dropzone>
<button deck="left" action="play" >
<pos x="341" y="332" />
<size width="93" height="37" />
<up x="1366" y="1029" />
<selected x="1469" y="1029" />
</button>
<button deck="right" action="play" >
<pos x="905" y="332" />
<size width="37" height="37" />
<up x="1582" y="1029" />
<selected x="1629" y="1029" />
</button>
<button deck="master" action="maximize" >
<pos x="14" y="150" />
<size width="54" height="35" />
<up x="1686" y="1029" />
<selected x="1750" y="1029" />
</button>
<button deck="master" action="settings" >
<pos x="14" y="198" />
<up x="1824" y="1029" />
<selected x="1888" y="1029" />
</button>
</skin>
this is my xml is anny thing wrong in it
</button>
</button>
</button>
</button>
<fader>
</fader>
</slider>
</square>
</visual>
</square>
</visual>
</textzone>
</textzone>
</textzone>
</textzone>
</textzone>
</textzone>
</dropzone>
</dropzone>
</button>
</button>
</button>
</button>
</skin>
Posted Sun 05 Apr 20 @ 10:45 am
You didn't add a grab zone to resize the skin
Posted Sun 05 Apr 20 @ 11:01 am
Thanks.
Can you help me where in xml i add the grabzone it what is the correct script for this skin please
Posted Sun 05 Apr 20 @ 11:06 am
