So lately I have been using the RampStopTime option set to 0.500000 and when I use the pitch effect and when I pitch the song up higher, the vinyl brake that is supposed to happen glitches out and it moves forward instead. https://drive.google.com/file/d/1RJVXoNko1VG-kPI2HbFuNH9iRKD-q8zH/view
There is a quick video link, I wasn't able to get audio or a proper screen recorder as I'm not on my personal laptop, but if you look at the waveform carefully it moves forward when I stop it. Please someone helped me with this issue, I really need this fix.
Thank You.
Thank You.
Posted Sun 15 Mar 20 @ 12:36 pm
adjusting the ramp start time caused this set to zero and it will stop
Posted Sun 15 Mar 20 @ 2:25 pm
