Topic: problem saving bpm analysis and cue points
Hello, since I have windows 10, everytime I close virtual dj 8 all saved analysis BPM etc. and cuepoints are gone reopening
Posted Sat 07 Mar 20 @ 1:35 pm
PhilWPRO InfinityMember since 2011
Check that you have write permission to the VirtualDJ folder under your Documents. If you are using an external drive, also check permissions to the VirtualDJ folder on each external drive.
Posted Sun 08 Mar 20 @ 9:32 pm
