Hi VDJ Team,
i recently bought a DDJ-1000 SRT, as we most of the times play B2B I found a bug in the Mapping
The input switches of CH1 and CH3 mute the wrong channel when switching from Input USB A to line.
Posted Sat 15 Feb 20 @ 10:06 am
I've tried now nearly all types of possibile settings.
It seems that the input switch on CH3 (left channel) mutes CH3 + CH1.
Posted Sat 15 Feb 20 @ 10:40 am
Now i've deleted all commands in related to those commands "SOURCE_USBA" "SOURCE_LINE" "SOURCE_USBB" and now it works.
Seems to be an issue with the factory mapping in VDJ on the DDJ-1000 SRT
Posted Sat 15 Feb 20 @ 10:48 am
Can anyone here confirm the bug I mentioned?
Can this be solved with a further update?
Posted Sun 16 Feb 20 @ 12:47 pm
Hi.
We will investigate and fix.
Thanks
Thanks
Posted Mon 17 Feb 20 @ 11:12 am
Last weekend we recognized that this issue is also for the channel EQ, so I deleted the channel EQ mappings. As the DDJ-1000 SRT has hardware EQ its working fine.
Please keep me up to date when this issue will be fixed.
Posted Tue 25 Feb 20 @ 8:38 am
Can any other user confirm my issue?
Posted Sun 01 Mar 20 @ 7:46 am
Removing the SOURCE keys created a bigger issue than the one you were trying to solve.
Anyway, a fix will provided soon (most likely with next software update)
Posted Tue 03 Mar 20 @ 11:03 am
sounds great! Looking forward for the next update, will test it immediately after the release.
Posted Tue 03 Mar 20 @ 4:15 pm
After investigating further your issue we could not find any issue with the mapper and muting in both USB ports.
However, there is a catch:
Both programs attached to 1000SRT must use the same mixer order.
If one computer uses 1234 and the other uses 3124 problems do arise.
VirtualDJ is capable to use mixer order 1234 without issues on 1000SRT. However we are not sure if Serato can do so as well.
Therefore when you play back to back with another person, please ensure you're using the default mixer order 3124 if the other person is using Serato.
If you both use VirtualDJ please ensure you both use the same mixer order.
PS: The EQ issue was found and will be fixed in next software update
Please let us know if that information was helpful and solved your issue, or if we need to investigate further
Posted Sun 08 Mar 20 @ 6:56 pm
Hi, recently there was an update to BUILD 5630 (2020-04-03), but there was no fix in the changelog.
Is it already fixed or do I have to wait for it?
Best regard, Jan
Best regard, Jan
Posted Mon 06 Apr 20 @ 6:20 am
Minor controller mapping updates don't appear on Changelog.
However the answer to your question is that yes, current update includes all fixes we have made (mainly the EQ issue)
Posted Mon 06 Apr 20 @ 11:20 am
Guys, sorry... this issue isn't solved jet.
It's still a mess, gain, audio channels and channel switches are totally disorderd (a huge mess).
I got a bit deeper into setting caused by another issue (new topic)
Can't figure out how to assign the channels correctly in the way they should - 3, 1, 2, 4
Currently I'm running V8.5-64 b6017.
Is there any way I could help you with this issue?
Please let me know if i can help!
Posted Wed 22 Jul 20 @ 4:58 pm
On the mapping page, the dropdown box that says Deck: should have a selection of choices.
There's also a settings option called mixerOrder.
Posted Wed 22 Jul 20 @ 5:09 pm
ok, here are my actual settings:
![](/img/317516/8420/1.jpg)
![](/img/317517/51487/2.jpg)
The Channel assignment, faders, deck assignment is correct.
But this is what I actual controll with exaclty those settings shown above in the gain and input section
![](/img/317518/33558/3.jpg)
Posted Wed 22 Jul 20 @ 5:30 pm
Yes, if you've got the Deck: dropdown box set to 1234 you will get 1234 on the mixer.
If you want 3124 you have to change the Deck: setting or the mixerOrder setting.
Posted Wed 22 Jul 20 @ 5:43 pm
Just open VirtualDJ settings and search for mixerorder
Set it to 3124 (or any other setting you like)
This setting is what dictates the order of the mixer.
DO NOT use deck assignment menu on mappers tab to change "order" as it will brake deck commands
![](/img/317523/34610/mixorder.png)
Posted Wed 22 Jul 20 @ 7:25 pm
So what's the point of the Deck: menu and the options there, if you're not supposed to use it?
Posted Wed 22 Jul 20 @ 7:32 pm
You are supposed to use it, but for other tasks.
The deck assignment there has an effect on ALL elements, not just mixer.
So, if you change 1234 to lets say 3412, you are effectively swapping all the decks:
Deck 1 play button becomes deck 3 play button. Deck 2 jog becomes deck 4 jog, e.t.c.
Also the deck assignment menu there is useful in order to swift a controller to use higher number of decks so that you can use 2 or more controllers to control more decks.
So, if you want to change ALL deck components order you use the deck assignment menu
If you want to change ONLY the mixer, you use the mixerOrder setting
Posted Thu 23 Jul 20 @ 6:41 pm
OK I understand. Thanks George.
Posted Thu 23 Jul 20 @ 8:22 pm
