Hi this has happend for me the first time about 6 month and happend the second time yesterday, i was talking to one of the guests and did not doing anything with the software or the control (ddj- sx3) Suddenly the sound just got distorted, i switch song but the bad sound was still there so i re-started VDJ and after that the sound was back to normal. Has any one else more than me has this problem?
Posted Sun 26 Jan 20 @ 12:41 pm
Right, i get the same thing again yesterday - no controller
the sound sudently played as if flanger was enabled only right deck
reset sound or disable effects did nothing
only restart VDJ fixed it
Posted Sun 26 Jan 20 @ 1:02 pm
I have had that a few times again restarted VDJ and fixed it,
Also had it where a track seems to have breaks in it, but i know the track is ok as I have played it many times before, I am running MC7000 buffer set at 256kb, powerdown options all turned off, and VDJ has exclusive access to the sound card on my dell laptop,
It start a few months ago.
is there a fix for this within the software?
Posted Tue 11 Feb 20 @ 8:06 pm
Anybody get a fix for this same problem here Mc7000 win 10 ??
Posted Sat 25 Jul 20 @ 10:13 pm
Adjust the buffer size on your MC-7000 driver.
Posted Sun 26 Jul 20 @ 7:08 am
