Topic: help needed with volume fader mappings
I have a numark mixtrack pro which has a malfunctioning left volume fader (channel 1) it jumps up and down when moved slightly. this is a hardware problem. they tried to fix it but apparently they couldn't so they send it back. it made me quit dj-ing as a hobby for a while. there's not much fun in it if you cant even record your mix because the hardware will mess it up.
but now I was thinking. if I could use the master fader as volume channel 1 and ditch the left volume fader I could still mix. but im struggling with the mapping commands. if anyone could help me out it would be greatly appreciated.
to be clear:
https://imgur.com/a/yxm9p3P
Posted Sat 14 Dec 19 @ 2:14 pm
master slider script
deck 1 volume
volume mapping script
action_deck 1 ? nothing : volume
Posted Sat 14 Dec 19 @ 2:45 pm
this worked perfectly. thanks alot. :D
Posted Sat 14 Dec 19 @ 5:26 pm
