Gys, please help. Tryng to set up my virtualdj in a few hours. Tried with swearing and without. I can not disable function of matching bpm while i pressing a sync button. I acctualy only want to sync the first beat without changing of bpm. I hope it possible.
Posted Mon 09 Dec 19 @ 11:16 pm
sync matches tempo that's it's job
Posted Mon 09 Dec 19 @ 11:41 pm
...however the answer is obvious or maybe it isn't.
sync & pitch 100%
sync & pitch 100%
Posted Tue 10 Dec 19 @ 12:19 am
sync & pitch 100%
sync & pitch 100%
Thank you for an answer. I am maybe wrong but in the older virtualdj versions I had that like a one time beat matching. Its makeing trouble when I try to mix songs with big difference in bpm. Fex. 80bpm vs 120bpm
Posted Tue 10 Dec 19 @ 6:11 am
You want to mix (e.g) 80 bpm and 120 bpm without changing the tempo of either track?
I'm confused....
I'm confused....
Posted Tue 10 Dec 19 @ 8:40 am
I'm confused....
I'm confused....
Yeah, som kind off pressing sync button few times in a row to much the first beat of square until i fade fully to the next track. Somtimes changeing of tempo harms the next track too much and I mixing them by the ear with doing that what i was describing.
Posted Tue 10 Dec 19 @ 12:32 pm
