I have a jogwheel with a simple script of : param_bigger 0 ? crossfader +2 : crossfrader -2
I want to hold down a button which will change the jog wheel to eq_low, as well a button to change it to eq_mid and high.
I know by now I should be able to nail this by now but I’ve tried var “$[name]” in countless different ways and I’m getting now where.
Any help would be appreciated, and you never know one of these days I might even get to level 2 on my scripting skills.
Posted Mon 04 Nov 19 @ 9:29 pm
rough glance,
button
set '$yourVar' 1 while_pressed
wheel
var '$yourVar' 1 ? param_bigger 0 ? eq_low +1% : eq_low -1% : param_bigger 0 ? crossfader +2 : crossfrader -2
*edit* btw, if you know jogs need param_bigger to work, you're level 2 already.
button
wheel
Posted Mon 04 Nov 19 @ 9:34 pm
Thanks locco, I take it the below looks viable?
var '$yourVar' 1 ? param_bigger 0 ? eq_low +1% : eq_low -1% : var '$yourVar' 2 ? param_bigger 0 ? eq_mid +1% : eq_low -1% : var '$yourVar' 3 ? param_bigger 0 ? eq_low +1% : eq_low -1% : param_bigger 0 ? crossfader +2 : crossfrader -2
I’ll try tomorrow, many thanks.
Posted Mon 04 Nov 19 @ 9:59 pm
looks like you get the idea, looks like you rushed the script though
var '$yourVar' 1 ? param_bigger 0 ? eq_low +1% : eq_low -1% : var '$yourVar' 2 ? param_bigger 0 ? eq_mid +1% : eq_mid -1% : var '$yourVar' 3 ? param_bigger 0 ? eq_high +1% : eq_high -1% : param_bigger 0 ? crossfader +2 : crossfader -2
Posted Mon 04 Nov 19 @ 10:03 pm
Many thanks, worked a treat.
Posted Tue 05 Nov 19 @ 3:59 pm
Please little help :
I config pad on my ddj-1000 . How make script : padfx 'ECHO' 0.4 0.5 0 0.1 ???? ( Source Mute ON ) smart_pressed . How write Source Mute ON ??
Posted Fri 08 Nov 19 @ 10:10 pm
mute on
Posted Sat 09 Nov 19 @ 1:35 am
padfx 'ECHO' 0.4 0.5 0 0.1 mute on smart_pressed . Not working. Button "Mute Source" not actived. :(
Posted Sat 09 Nov 19 @ 9:07 am
you're missing &
Posted Sat 09 Nov 19 @ 9:29 am
Rekordbox Echo from pads pionner-ddj1000 is script : effect_button 1 on smart_pressed & padfx 'ECHO' 0.5 0.5 0 0.7 smart_pressed
Posted Sat 09 Nov 19 @ 2:13 pm
Read the help for padfx carefully.
The correct syntax is:
padfx 'ECHO' 0.4 0.5 0 0.1 'TRAIL:on' smart_temporary
Posted Sat 09 Nov 19 @ 2:17 pm
Then it does not work alike Rokordbox pad nr.8 . My endeavor is imitate pads effects from origo PIONEER .
Posted Sat 09 Nov 19 @ 2:38 pm
Thank you .I understood your idea.
Right for me :
padfx 'ECHO' 0.4 0.5 0 0.1 'mute:on' smart_pressed
Posted Sat 09 Nov 19 @ 3:57 pm
