Topic: Problem With Shader Texture Loading
VDJ 2020/64-bit appears seem to have a problem with shaders when texture is involved. The shader runs but since there is no texture loaded they mostly appear empty.
A couple of examples:
This does't show anything at all in VDJ: https://www.shadertoy.com/view/4lcGWr | view on shadertoy | copy link
This one shows, but with missing textures: https://www.shadertoy.com/view/XtdGR7 | view on shadertoy | copy link
Computer specs: i7/NVidia 1060 + Intel HD4400 (tested with both).
Posted Sat 26 Oct 19 @ 5:36 pm
AdionPRO InfinityCTOMember since 2006
Problem seems to be shaders with multiple textures.
The second one will be fixed in the next update. For the first one it seems there's another problem as well but I haven't found it yet.
Posted Sun 27 Oct 19 @ 2:03 pm
