Topic: Audio Settings
pirata0PRO InfinityMember since 2009
Is it possible to set multiple 'AUDIO SETTINGS'. I currently use the laptop with virtual dj8 with the external USB ESI UDJ6 Audio interface. I now also want to use my DenonDJ MCX8000. The intention is to use them both, not together together, without having to adjust the settings each time. Is it possible to select the correct setting with a kind of menu?
Posted Sat 26 Oct 19 @ 2:12 pm
Posted Sat 26 Oct 19 @ 2:14 pm
Hello, thanks. I will look for it.
Posted Sat 26 Oct 19 @ 2:25 pm
