Topic: VDJ 2020 - Controller connection
I have noticed that the connection to my controller is not quick or automatic once I plug in the USB cable. More specifically, when I switching with a another dj using the same controller, I have to go into the settings to select the controller before I can begin to use it.
Is there a way to setup VDJ 2020 so that the connection is instantaneously connected to controller once the USB cable is connected?
Posted Wed 23 Oct 19 @ 10:43 pm
