Topic: Music tempo and sound issues
I've noticed that some songs play differently on 2020 than normal. Either they are sound a little chipmunkish or the tempo is too slow and has to be speeded up. What's up with that?
Posted Thu 17 Oct 19 @ 2:17 am
Check the "Auto Match KEY" setting (which is enabled by default on VirtualDJ 2020)
What it does is that it changes up/down one semitone the KEY of the track you load on a deck in order to match it harmonically with the track on the other deck.
If the track you load needs a bigger change than one semi to become compatible then it won't alter the KEY.
Posted Thu 17 Oct 19 @ 7:59 am
