Topic: Virtual DJ 2020 Freeze problem
When I mix the half of my dj set suddenly freezes and I can not do anything but the song still goes and I can not do absolutely anything I have to turn off the program in the task manager. And whenever I install the program I install 32 bit version but I need 64 bit version
what can I do?
Posted Fri 11 Oct 19 @ 5:31 pm
user19959675 wrote :
what can I do?
You can download the 64 bit version.
Please provide at least some information, so someone can help.
What computer (PC or Mac)? Are you using a controller or external audio interface, and if so, what one?
What are you mixing (audio or video)? Are you streaming/broadcasting?
Posted Fri 11 Oct 19 @ 5:54 pm
And how and where can i download the 64 bit version?
i use a PC
i'm not using a controller or external audio interface (in the future i will buy a controller)
I mix audio and i want to start to do twitch mixes with the program default video visualizer
No, but if i solve that problem, i will start to do twitch streams
Posted Fri 11 Oct 19 @ 6:09 pm
Surprisingly, you need to click the area that says Download along the top edge of this forum. Then cick the text or the big button that says Download.
Posted Fri 11 Oct 19 @ 6:12 pm
if I do that, automatically download 32 bit version
but my pc have 64 bit
Posted Fri 11 Oct 19 @ 6:20 pm
No, the default download is now 64 bit.
Posted Fri 11 Oct 19 @ 7:14 pm
Posted Fri 11 Oct 19 @ 8:00 pm
Posted Sat 12 Oct 19 @ 8:19 am
AdionPRO InfinityCTOMember since 2006
Are you running windows 10?
If not the 32 bit version is correct
Posted Sat 12 Oct 19 @ 9:11 am
I'm running Win 10 on a Dell E5510. i5 Dual Core and 6 gigs RAM. I'll be playing along fine and all of a sudden the display freezes. If I move the mouse it will jump and then freeze. I lose all function controls. It will finish the song but remains locked.
If I let the whole system set for 10 minutes it comes back up and will play for a while and then lock up again.
Clues?
Posted Tue 12 Nov 19 @ 2:54 am
check for overheating ... then remove anything you don't really need from the machine and optimize it and do a latency check.
Makes sure drivers are all up to date especially video ... good luck dell machines sometimes suck at real time audio
Posted Tue 12 Nov 19 @ 11:15 am
PhilWPRO InfinityMember since 2011
Posted Tue 12 Nov 19 @ 4:19 pm
