My cross fader controls the VDJ one on the screen but it makes no difference to the audio output.Both channels remain audible.
Posted Sat 05 Oct 19 @ 11:09 am
Have you got the crossfader assign switches set correctly?
Posted Sat 05 Oct 19 @ 11:14 am
In the app settings?
Posted Sat 05 Oct 19 @ 11:31 am
They are correct on the controller
Ok, got to test the easiest thing first, next easiest, perhaps you have the setting crossfaderDisable switched on?
Posted Sat 05 Oct 19 @ 11:38 am
Posted Sat 05 Oct 19 @ 11:39 am
Next easiest, is the software crossfader assigns following the hardware?
If not that then a pic of your audio config please,
Posted Sat 05 Oct 19 @ 11:50 am
Thanks mate.Seemed to get it working.All I did was change from performance to pro.
Posted Sat 05 Oct 19 @ 11:43 pm
