Hello
I have installed virtual dj 2020 and with the new skin in pro mode the beats counter for plates 3 and 4 does not work, I am using an mcx8000 and plate 1 and 2 are in engine mode I only use 3 and 4 with virtual, with other skins this does not happen, also note that the new skin uses between 10 and 20% more of my cpu (I do not have dedicated graphics on that laptop) one of the things that I have always liked most of virtual is its low use of resources even playing 2 videso simultaneously
regards
regards
Posted Thu 03 Oct 19 @ 4:23 pm
I have solved the problem of using the CPU by making some adjustments to the skin, but I still do not see the beats counters of plates 3 and 4, any solution, please
Thanks in advance
Thanks in advance
Posted Fri 04 Oct 19 @ 6:01 pm
EL Corsario DJ wrote :
avocado 3 and 4
So that's the two on the right, yes?
![](https://i.dailymail.co.uk/1s/2019/09/15/00/18487194-7464799-image-a-30_1568502619078.jpg)
Posted Fri 04 Oct 19 @ 6:05 pm
jajaja traslate error sorry
Posted Fri 04 Oct 19 @ 6:08 pm
What do you mean by "beat counter"? If you're referring to the four horizontal lines, then they work on all four decks on my system.
Posted Fri 04 Oct 19 @ 6:10 pm
I will post a screenshot or video so you can see the problem
Thank you
Thank you
Posted Fri 04 Oct 19 @ 8:26 pm
