After updating to vdj 2020, I cannot use and even see any plugins apart from the default and I have install the plugins several times.
I need your help
Thanks
I need your help
Thanks
Posted Tue 01 Oct 19 @ 4:58 pm
Have you updated from 32 bit to 64 bit VDJ? If you have then you will need 64 bit plugins.
Posted Tue 01 Oct 19 @ 5:07 pm
OK senior
Posted Tue 01 Oct 19 @ 6:25 pm
